how to get oil dipstick tube out?
Discussion in 'Engine & Performance' started by strokin393, Mar 13, 2011.
  1. strokin393
    strokin393 Full Access Members
    199
    Feb 7, 2011
    Va
    I need to get the oil dipstick tube out of my 97 expedition because it has a piece of plastic stuck down in it from the top of the dipstick breaking and fell in and new dipstick won't go. I've tried forcing it to knock it into pan and drain oil to get it out but its stuck in tube.
  2. markanthony
    markanthony Full Access Members
    79
    Dec 29, 2010
    Bountiful
    If the tube comes out. Two ways come to mind. It could be pressed in and a pair of pliers/vise grips and a good tube. Or there may be a little bolt with a u/y shaped metal holder on the block that holds it in. Other then that. I don't know of a way that holds them in. Like I said. If they come out. they may be welded in.
    I would feel around the bottom of the tube and see if you feel a bolt and holder. See if you can see it. The last tube That I dealt with that was pressed in. I had to replace cause I crushed it when removing it. So I replaced it with a nice chrome tube from the local auto part store.
  3. strokin393
    199
    Feb 7, 2011
    Va
    It doesn't want to come out. I don't know what to do.
  4. ELVATO
    ELVATO Super Mod Supporting Member
    2,637
    19
    Nov 25, 2006
    Orlando, FL
Share This Page
