inside molding around rear hatch
jvanatta
Missouri City, Texas
how does the plastic molding at the rear hatch come off? the rear windshield washer is leaking inside the vehicle at the rear side window. 2014 Expedition
Big Brian
Farmington Hills Mi
they just pry off. Just be careful and take your time they will just pop right off. Use a plastic scraper or prybar to get them started
ExpeditionAndy
Fort Wayne, Indiana
Before you go crazy taking the molding off, remove the third brake light and pull out the washer tubing as far as it will go and look for breaks in the tube. It might be as easy as just cutting the tubing at the break and sticking in a piece of brass tubing. Just a thought.
ExpeditionAndy
Fort Wayne, Indiana
what is the third row brake?
Third row brake light is the one above the hatch with the sprayer nozzle on it. If you remove the two screws that hold it in you can pull out a good length of the tubing and you can check it for cracks or leaks.
fuzzmanmatt
Lol "third row brake"... Center high mount stop light. Two screws, super easy to remove, check the connections, put it back together.
Sent from my SM-G925T using Tapatalk
