Installing a aux tranny cooler.
AvroAero
Toronto, Ontario
I want to install an auxiliary tranny cooler along side my stock one. Is there anything to it really, or is it just disconnect tap into the line and don't worry about the air in the rad. I'm thinking so that it'll just push the air out and into the transmission which I think wouldn't hurt.
JUST4FUN
Admin
Il
over cooling trans fluid is just as bad as overheating it. go to a trans shop and ask your ? the winter time is what im talking about
green03
College Station, TX
As long as it goes through the factory heat exchanger in the side tank of the radiator (internal) first then to the AUX cooler you will be just fine..... Fluid does run through the trans cooler at all times.
Matt R
