cleatus
I have a 98 expedition. This started with a problem blowing fuse 14. The power windows wouldn't work.
I unhooked the back switches for the windows. With a lot of trying couldn't get the fuse to blow by running the front windows but know the interior lights won't go off. The only odd thing I did will searching for a probable cause. The overhead light has been sketchy for a while. The little printed flat wire contact thingy was kinked up and broken so I unplugged it and took it out. Can't find a replacement except for a possible junk yard donor. I also sprayed some silicone spray in the drivers door hinge detent, the door was creaking. I don't think there are any switches in there. Since then the lights stay on. The running boards are not lit up and the door is ajar light is not on. I thought possibly a relay might be stuck but I do hear and feel them clicking. I had a spare head light switch and switched it and it still stayed on. The manual interior switch light had no bearing on the lights. Anyone have any ideas.
