Intro and Question about payload and towing packages
Discussion in '3rd Gen - 2007 - 2017' started by cvbrewer, Jul 17, 2017.
  1. cvbrewer
    cvbrewer Member
    48
    Jul 17, 2017
    Fairfield
    Hi Guys,
    My name is Chris, and I'm driving an 04 Honda Pilot. I'm looking hard at G3 Expeditions. I am interested in having max towing ability, but that really limits my choices in the used market.
    I understand that there is significant overlap between the max payload and max towing packages.
    Given an G3 Expedition with max payload package, could it be made into max towing configuration by changing simple things like harnesses and mirrors?
    Thanks,
    CV
  2. ExpeditionAndy
    ExpeditionAndy Supporting Member Supporting Member
    59
    3,195
    776
    Aug 31, 2013
    Fort Wayne, Indiana
    CV Welcome to the Forum. What gives you the Max Tow capability is the HD tow package, it adds a larger radiator, a transmission cooler, in most cases a 3.73 rear end, a class IV hitch, (I believe that is the right class,) and a 7 pin connector. All of that stuff can be added aftermarket but it could be pretty pricey to do it that way.
    I'm not sure about the older Gen 3 Expeditions, by my 17 has a max tow capability of 9,000 Lbs with 4WD the 2WD models have 9,100 lbs towing capacity.
  3. cvbrewer
    cvbrewer Member
    48
    Jul 17, 2017
    Fairfield
    Gotcha. What I was wondering is if the cooler, radiator, and axle ratio for the tow package overlapped with the max payload package.
  4. Bedrck47
    Bedrck47 Full Access Members
    5,419
    533
    Jul 4, 2014
    Elizebethtown, PA
  5. 07xln
    07xln Full Access Members
    38
    262
    130
    Dec 11, 2016
    Dallas
    There is no such thing as a "max payload package" only an HD towing package.
  6. 1997SCEBFEX
    1997SCEBFEX Full Access Members
    1,088
    77
    Nov 5, 2011
    Northwest Panhandle
    Combined Gross Vehicle Weight is one of the most important factors imho.
  7. cvbrewer
    cvbrewer Member
    48
    Jul 17, 2017
    Fairfield
    I see. Dealers are advertising 7760#payload package or 7760#GVWR package. What do they mean?
  8. 07xln
    38
    262
    130
    Dec 11, 2016
    Dallas
    I'm not sure. Ive never seen them advertise a "payload package". Where are you seeing this? Also what year model and trim are you looking at? Not sure why there would be a max payload package and it not have a towing package accompany it. I have a 17 EL and according to the sticker inside the door the GVWR is 7520#. That number will differ a little between trims and years.
    Again without knowing exactly which model you're looking at its hard to give an educated answer. If you're going to be doing any towing then find one with a towing package and call it a day
  9. cvbrewer
    cvbrewer Member
    48
    Jul 17, 2017
    Fairfield
    Understood. Thanks.
  10. JollyRoger
    JollyRoger Active Member
    35
    Sep 21, 2015
    Google "2010 Ford Expedition Towing Capacity", (insert whatever year you are looking at), and you should be able to find the official Ford document. For example, this is for my 2010, which is set up for 8900 lbs because it has the tow package. 4x2's are 9200 lbs. Scroll down to the second and third pages for details.
    http://www.ford.com/resources/ford/general/pdf/towingguides/10FLMrvEXPEDITIONsep09.pdf
    But as stated above, this doesn't mean you want to be pulling anything close to this. Just from experience, once you get to 5-6,000 lb trailer, you should probably be looking at an F250, etc. That's just me. Keep in mind that everything is dependent on GVWR. How many people and how much luggage do you have in the truck, etc. And anything over 6,000 requires a weight distributing hitch.
    Good luck!
Share This Page
