keyless entry
mohs00
michigan
i have a 00 xlt with the numbers on the drivers door for keyless entry and i was wondering if anyone knows were the default number is located at in order to gain access into the truck with out the key thanks for the help
mjdh_80
Wyoming, MI
Mine was on a card in with the owners manual. Other than that I don't know where you might find it.
warschool
ohio
Under the dash taped to the computer module is the 5 digit factory code. I think it is on the drivers side.
M
mohs00
michigan
all right ill have to climb under there and see if i can find it thanks for the help
M
mohs00
michigan
well i found a or the number but it didnt work so i dont know if its the right number or if my key less entry just doesnt work at all i guess ill have to check out some fuses
doug-ocon
Maryland
I have read that if all the keys do not light up when pressed the keypad is prbobly bad due to water damage...will need to be replace
