Location of EVAP cansiter purge solenoid?
Discussion in 'General Discussion' started by ghettoracer, Jul 11, 2010.
  1. ghettoracer
    ghettoracer Full Access Members
    134
    Apr 6, 2010
    Oregon
    Where is this part located?
  2. mikegigabyte
    mikegigabyte Full Access Members
    100
    Jul 4, 2009
    san diego
    are you having a smog problem or idle?
    I remember looking for this before for some reason, im thinking it was a code that popped up for me, I think its near the gas tank somewhere because I wanted to replace that part too, but ended up being something else so I never got to it
  3. ghettoracer
    134
    Apr 6, 2010
    Oregon
    It was a p1451 code but it turned out to be an electrical issue to that particular part.
  4. mikegigabyte
    100
    Jul 4, 2009
    san diego
    Well I now remember why I had looked for that part, I had reset my computer and went to get smogged and didnt pass because the computer didnt go through all the checks yet. A week later I was still waiting on one code to finish and I had over 750 miles. I looked up the part and it was that canister but later I found out I needed to drive under 40mph for a while for it to check it. Thats why I never had to fix it.
  5. ELVATO
    ELVATO Super Mod Supporting Member
    2,637
    18
    Nov 25, 2006
    Orlando, FL
    On the 2000-2002 Expeditions, the evap canister:
    -is located along the left frame rail behind the fuel tank.
    -contains activated carbon.
    -stores fuel vapors.
    On the 2003 (and I'm guess up to 2006) Expedition, the evap canister:
    -is located above the spare tire carrier behind the fuel tank.
  6. ghettoracer
    134
    Apr 6, 2010
    Oregon
    Yeah mine turned out to be a bad line and popped that code P1451. I guess those lines are really fragile after time.
  7. Ex0r
    Ex0r Member
    23
    Oct 29, 2010
    Jackson, MI
    You said it was an electrical problem? What was the solution to it, and what line was it? Are they just normal rubber hoses? I have the code too, and am looking to get it fixed.
    Does it take long to diagnose the hoses and replace them?
  8. ghettoracer
    134
    Apr 6, 2010
    Oregon
    well the electrical problem was for the ECM and wasn't grounded properly but that wasnt throwing the code. The vacuum lines were bad and were causing it to do this hesitation going up hill and making it flash the CEL and stood on afterwards. Took it to a shop and they replaced all the EVAP solenoid lines and the code went away. you can use a normal rubber hose. but you got to get the right size. my mechanic used the smoke leak detector machine to find it.
Share This Page
