AWD EXPY
When the GEM would randomly make the window go down, the fix was to rewire the switch output from the gem, instead straight to the motor. But you lose the one-touch-down feature.
So with a couple relays, a handful of diodes, and some wire jumpers, the OTD feature can be back, without the gem doing it's random, unwanted opening of the window.
It can probably be improved on. When you go to the link, you might be able to interact with the switches of the circuit. If it works, click and hold the down, or click the OTD switch.
Click the GEM box to stop it. This could work! I'll give it a try on some summer day.
Hoping the link or pic works.
http://www.falstad.com/circuit/circuitjs.html?cct=$+1+0.000005+10.20027730826997+50+5+50%0A178+240+80+384+80+0+2+0.2+0.000011999760037827211+0.05+1000000+0.02+20%0Ag+144+304+144+336+0%0Ag+768+128+768+160+0%0A178+384+288+240+288+0+1+0.2+0.000011478242084978184+0.05+1000000+0.02+20%0AR+720+320+752+320+0+0+40+12+0+0+0.5%0Ad+512+288+480+320+1+0.805904783%0Ad+608+256+608+128+1+0.805904783%0Aw+384+320+480+320+0%0Aw+608+128+640+128+0%0As+608+256+720+256+0+1+true%0Aw+608+384+480+384+0%0Aw+720+256+720+320+0%0Ad+480+384+480+320+1+0.805904783%0Ag+384+336+384+368+0%0Ad+608+48+608+128+1+0.805904783%0Aw+240+128+240+160+0%0Aw+240+160+384+160+0%0Aw+464+160+464+288+0%0Aw+464+288+384+288+0%0Aw+384+96+512+96+0%0Aw+240+80+240+112+0%0Aw+384+160+464+160+0%0Aw+512+96+512+288+0%0Aw+240+32+240+80+0%0Aw+384+48+608+48+0%0Al+640+128+768+128+2+1+0.000011478471150911445%0Ab+72+159+-11+97+0%0Ax+-5+145+63+148+4+30+GEM%0Aw+720+320+720+384+0%0Aw+608+384+480+416+0%0Aw+480+416+32+416+0%0Aw+32+416+32+160+0%0As+608+384+720+384+0+1+true%0Ax+678+102+739+105+4+24+motor%0Ax+640+227+697+230+4+24+down%0Ax+638+409+688+412+4+24+OTD%0Aw+240+112+48+112+0%0As+16+112+48+112+0+0+true%0Aw+-32+112+16+112+0%0AR+-32+112+-80+112+0+0+40+12+0+0+0.5%0Aw+240+304+144+304+0%0Ax+328+127+427+130+4+20+GEM%5Csrelay%5Cs%0Ax+208+333+299+336+4+20+OTD%5Csrelay%0A
