Motor oil change
Discussion in '3rd Gen - 2007 - 2017' started by Arturo Gonzalez, Jun 13, 2018 at 9:12 AM.
  1. Arturo Gonzalez
    Arturo Gonzalez New Member
    40
    May 25, 2018
    San Diego
    Good morning. I’m new to the group. I just bought a 2017 Black Expedition El Limited with 51,000 miles at carmax here in California. I was wondering should i do the oil change at a ford dealer or have my mechanic do it? Should i stick with using motorcraft or do you recommend something better?
  2. MidwestBoater
    MidwestBoater Active Member
    40
    28
    23
    Dec 12, 2017
    St Louis
    I can't comment on your question as to who should do it as I do my own maintenance, but it's recommended to use a name brand full synthetic and shorten the interval to at least every 5,000 miles due to fuel dilution of the oil. Myself, I use motorcraft filters and pennzoil platinum every 5k when not towing, every 3-4k when towing frequently (boating season).
    Arturo Gonzalez likes this.
  3. Don Hall
    Don Hall Supporting Member Supporting Member
    86
    39
    Jun 8, 2018
    SANTA CRUZ, CA
    Changing oil is not hi-tech. Depending on your physical size and condition, you can access the oil drain plug without jacking the SUV. It takes about 20 minutes (I'm 86).
    Since I own Corvettes, I use Mobile 1 purchased at Costco with $10-off coupon. If I don't feel like crawling under the vehicle, I take it to OIL CAN HENRY (now VALVOLINE),
    furnish my own oil and filter.
    As suggested by MidwestBoater, use a full synthetic oil which will withstand hi-engine temps, especially when towing.
  4. 07xln
    07xln Full Access Members
    38
    570
    259
    Dec 11, 2016
    Dallas
    If your only two choices are the dealer or "your mechanic" I would take it to the mechanic. Dealers simply cant be trusted to do something as simple as an oil change and do it right
    Like others said, good synthetic and whatever filter you want
  5. Flexpedition
    Flexpedition Full Access Members
    765
    273
    May 26, 2015
    midwest
    There are over 3,000 Ford dealerships in the US alone. You got them all figured out?
    2008 here, purchased new - every single oil change done at various Ford dealerships. Never an issue.
  6. coolzzy
    coolzzy Full Access Members
    38
    113
    44
    Apr 16, 2018
    Idaho
    If you bought it certified pre owned or bought an extended warranty, it would be nice to have a paper trail of oil changes showing proper maintence was performed if you ever have to file a claim. The ford dealer runs specials every few months on their "works" oil change for 30 bucks. It includes tire rotation and basic inspection of fluids in addition to a Motorcraft filter and oil. That's my plan for my 17 expy while it's under warranty, and I'll change it every 5k miles. Remember the ecoboost calls for 5w30 oil unlike many ford's that switched to recommending 5w20, so make sure your dealer or oil change place puts the proper weight in.
    I know for certain that oil changes, tire rotations, etc, at a Ford dealer show on a carfax, some large chain shops do as well but small shops most likely don't.
  7. 07xln
    38
    570
    259
    Dec 11, 2016
    Dallas
    It only takes 1
Share This Page
