Multiple electrical issues....help?
Bedrck47
Elizebethtown, PA
Rather than buying new parts do some testing first. Check the switch to see if you have power in and out Check the connector for the mirror to see if you have power to the motors. Just because the signals work does not mean the rest is ok The signals are a totally different circuit
stamp11127
Temple, Georgia
For giggles you may want to check the charging voltage @1500 rpm with the blower motor on high and the high beams on.
S
swagfu
Deland, Fl
Thanks guys. Can you tell me how to check these things? I don't mind checking and testing, just not sure how to do it.
Bedrck47
Elizebethtown, PA
Look at the prints C511
Disconnect the connector for the Switch Then take your voltmeter and read the voltage between pin 1 and pin 5 on that connector
Post the results
S
swagfu
Deland, Fl
Thank you. Might be a few days as work will get in the way until about Wednesday or so. Working retail can interfere with other things quite often. When its my weekend to work, its a brutal schedule. I appreciate the help.
S
swagfu
Deland, Fl
OMG I finally got a chance to work on the truck today. My brother sent new mirrors out of the blue. Took a couple hours but I managed to get them on. They work perfect. My only thought is that the motors gave out. I just plugged and played them and they worked. How else could it be explained?
