shadow460
I have put two Murray compressors on my 98 Expedition last summer. The first was rebuilt and bad straight out if the box. It refused to develop high pressure or any kind of suction; in residential AC terms this is called "inefficient compressor". I changed it last June, this time springing for a new Murray one from O'Reilly. Last Monday it was 60 degrees out so I put a new water pump on thr truck. I noticed then the compressor was running constant and it was comfortable in the truck. I was actually impressed by that. I'd half expected it would leak a bit and the compressor would cycle in that weather.
An hour ago I filled up and checked fluids and checked the water pump for leaks. That's fine but that eight month old AC compressor is leaking oil--already!
It actually struggled a little in the hottest months last summer but if I closed off some vents like I've done before it would get to about 60 degrers at the vents that were open.
I wonder if anyone else has consistent trouble with parts house compressors. Should I just buy the Motorcraft one and be done with it?
