studabaker
Im gonna get right to the point first, and then provide story.
2001 expy xlt purchased 2012 and blew trans 2013 cheap swap for 1000 bucks and has not been the same since. He was upselling me to a eddie bauer transmission from a compatible year, I dont know if the wrong transmission was installed or a slight variation may be causing this problem???
At 65 mph it becomes more noticeable and it is felt to a lesser degree at slow speeds. I pulled off the next exit. In normal driving it is annoying however on a trip of several hours it begins to damage cv axles and front differential. first i swapped out a front differential and it was improved but not gone. It feels like a bearing and I have had shops do some tests and other work on it but cannot find the damage. I have done some work to so that is suspect I admit but has been ruled out by these tests. A moment of clarity was when it was felt and put in neutral and the motor rev to 3000. Occasionally when it (was) bad at 2000 rpms the engine really shakes and I have to slow down and crawl back. This lead me to misfires which I had but those are now resolved to the best of my knowledge. I got a torque converter a few weeks ago and it is improved but not the problem. I was sure. I plan on going through and locating the frame mounts or something to check the condition
I feel it in the front on acceleration a bit where there is flex in the driveline? or something is off slightly.
Tests:
continues to shimmy at 60 with engine in neutral and changing rpm yet constant shimmy?
transmission checks out with expert
engine checks out with mechanic
front differential checks out with long turns both directions test at near 60 when shimmy is felt.
In theory it would be worse on one side or the other.
It seems like there resistance in the front drive line after the transfer case.
transfer case swapped out for pulled one.
drive lines balanced
rear diff rebuilt
new wheels and tires
suspension checked out by 4 wheel store.
This seems to narrow it down to the transmission, or transfer case? mounts or ??
thank you for any help
Tests:
rear diff rebuilt
