juan214
Sorry guys it's on the Windstar.
Need some input here. Need to change some front end parts. Started with the drivers control arm. What a PIA, anyway ended having to disassemble everything to get to the rear bolt. Would not budge at all. Sprayed with Kroil now the sleeve and the nut just spin. Need some ideas to take this apart. Have no torch.
Changing out both lower control arm Drivers ball joint move freely. Both Stabilizer links one the boots shot a nut let go at one point. the other moves freely. Got both outer tie rod ends Drivers seems fine. Got both inner tie rods Drivers seems to have some in and out movement. Replacing both axles seals has dried up fluid around them.
Need to do an inspection on the CV Axles to see if they need replacing. They currently make no noise.
Again sorry guys
Again sorry guys
