Hey there! New member here in AZ.
I have a 99 EB 5.4 with EATC climate control. I replaced the heater core that had been leaking severely. When I got the dash back on I adjusted the controls with the engine running while watching the blend door actuator under the dash. it moved but not as much as I thought it should. So I drilled an "inspection" hole behind the glove box and into the plenum cover. I watched the blend door open and close when the hot/cold buttons were adjusted, but the movement was intermittent. I'd checked the blend door for cracks prior to installing the heater core and found none. I left things alone for a day while I drove as normal. When I had time to work on it again, the actuator quit working. I figured it was damaged from the coolant leaking into the cab so I decided to replace it. It was indeed full of coolant. I bought a Dorman actuator (part #604-216) and plugged it into the wiring harness to test it before installing it. I adjusted the controls with the ignition in the "run" position and nothing happened. I'm at a loss as to what could be the problem. I've searched for this problem, but the only threads I find are incomplete or deal with the "manual" controls. I checked all my fuses and they are all good.
My questions are:
Could I have bought the wrong actuator? Would the harness fit the "manual" actuator? The part number was identified as being for the main blend door for "automatic" controls.
Is there a possibility the EATC head unit is bad? It still sends air to the panel, floor and defrost when adjusted.
How do I test the voltage at the connector? I just bought a multimeter but I'm not sure which wires in the harness deliver power to the actuator.
I know there are a lot of people on this site who've gone through the heater core/blend door ordeal and have lived to tell about it. I'd appreciate any advice as to what I should do next.
Thanks in advance.
My questions are:
Thanks in advance.
