JediKnight2
Just upgraded from a 1997 GMC Jimmy 4x4 to a 2006 Ford Expedition Limited with 111,000 miles. Picked her up for a good deal I think. Is there a page that lists all of the fluid capacities and types? I know Ford changed weights on differential fluids so I just want to make sure I'm using the proper weights of the fluids. I think I can do the rear differential and transfer case fluid changes on my own. The transmission fluid change is too messy probably to do in the driveway. Will also need a u-joint, but I can probably do that unless it's worth it to let the shop do it. Anything I should do right off the bat?
