curleywon
I have no heat front or rear. Today I back flushed the entire cooling system with the kit which I installed in 2013 when I replaced the front heater core and radiator. I saw some rusted metal coming out but not enough to indicate a major blockage. I cut a hole behind the glove box to insure that the blend door is functioning properly. After filling the system, I still have no heat. Neither of the hoses going to the core are even warm and neither is the core itself when I touch it from the inside through the hole that I cut. I replaced the thermostat also. What am I missing? I also used a shop vac to blow as much water out of the system as possible before refilling. It only took 3 quarts to fill. I need help. I need heat.
