No signal from brake stop light to tekonsha brake controller
Dwilds
St Petersburg FL
Having a hell of a time troubleshooting an issue with a brake controller. I installed a Tekonsha P3 to the factory pigtail on my 2003 Expy XLT using a plug and play Ford-to-tekonsha harness. The controller will activate the brakes when the manual lever is used on the controller but not automatically when braking the Expy. All lights work on the trailer and all applicable fuses on the Expy are confirmed good.(all tail lights work)
I had a local trailer shop check the factory pigtail and there is no signal coming from the stoplight switch which activates the controller. The diagnostic stoplight screen on the brake controller shows a constant 0 volts when pressing the brake pedal. The local trailer shop said the next step is to have The Ford dealer diagnose. Would like to avoid a 100 dollar dealer diagnostic fee.
Anyone ever see a similar issue?
Bedrck47
Elizebethtown, PA
Look on print 90-04 on left side of print you will see C213 which is located behind the drivers side kick panel See print 151-20 and 150-23
You need to check if you have 12 volts into and out of that connector when the brake pedal is pressed
  • 90-04.pdf
  • 95-03.pdf
  • 151-20.pdf
  • 150-23.pdf
max357
