You might check the plugs and make sure they are tightened to specs. If it sounds like a light exhaust leak I would check the plugs like I suggested. Just a thought.OK I'm not a patient guy... Drove it today and picked up a new boot, spring and some grease. I put it in and drove it around. The idle is better and almost all of the stutter is gone but what stutter IS there is harder if that makes sense. Also when I got into it hard it sounds like what I can only describe as quiet popping from the back of the engine.
It only threw the code twice - the CEL blinks but won't stay on...
I plan to drive it this week and the next. Before I tackle replacing the plug or messing with the injector.
Thoughts?
