what obd2 adapters work with iPhone? I have FORScan but need a reliable adapter to work with my iPhone 6 to disable hyper flash
I ended up buying a obd2 that has a usb plug for my laptop. I only need it to turn off bulb out indicator.Those really are 2 different questions. The iPhone has nothing to do with programming with FORSCAN. The iPhone only runs FORSCAN lite and it can make no changes.
You have to use FORSCAN with a full license on a Windows machine to make changes.
I use an OBDLink MX BT for my programming with my laptop. With the BT connection I can still use my WiFi in the laptop for access to my home network.
I use a Kiwi3 for my iPhone for FORSCAN Lite, Dash Command, and OBD Doctor. It is fast, but does not work with the full FORSCAN, as far as the last time I checked.
Thts the one!Yep, with the switch in the down position.
Was it easy getting the extended license to download and work?When connected the Forscan screen prompts informed me where to put the switch for what I wanted to change. Simple.
-- Chuck
