CSVT#49
So I wanted to run a diagnostic check on my 05. I plugged in my scanner to the OBDII port, turned on the key, and no dice. The scanner powers up but says 'Error' when I try to read the codes. Not having faith in my scanner, I grabbed my SCT X3 programmer and tried using it, same thing with an error message. I checked the fuse, as some have said this can be the culprit, however having power there left me skeptical, but yes the fuse was fine as I had expected it to be. Wiring going to the port looks good. I'm going to disconnect the battery and let it sit for a while and then hook it up and try again, but other then that I have no ideas. Have any of you run into this before and found a solution??
