Oil around spark plug boots
Discussion in 'Transmission & Drive train' started by smount101, Apr 22, 2011.
  1. smount101
    smount101 Member
    Mar 30, 2011
    delaware
    Just change the plugs and coil packs in my 2000 expedition last night. When I pulled the boots on 3 of the plugs and pulled the socket out with the old plug on it the socket was covered in oil. Only 3 of the cylinders looked like this. Put everything back together and runs fine just wondering where this oil would come from. Any ideas? Thanks
  2. Quevy50
    Quevy50 Member
    May 11, 2011
    Myrtle Beach, SC
    Oil in Plug Holes
    What motor are you working on?
    Could be several things:
    (1) Oil spillage when changing oil. Oil that gets spilled on to the valve cover and the intake can seep into the plug holes.
    (2) Valve Cover gasket: If gasket on the valve cover is leaking on the intake side, oil can seep into the plug holes.
    I just fix the same problem on my 2000 Expedition by replacing the valve cover gaskets. It was a real pain in the azz!
Share This Page
