Oil catch can
Wody B
Florida
I Looked up the scheduled maintenance from ford and this is the fluids that they recommend.
Automatic transmission fluid (U.S. and Mexico): Motorcraft® MERCON LV Automatic Transmission Fluid XT-10-QLVC WSS-M2C938-A MERCON LV
Automatic transmission fluid (Canada): Motorcraft® MERCON LV Automatic Transmission Fluid CXT-10-LV12 WSS-M2C938-A MERCON LV
Front axle fluid: Motorcraft® SAE 75W-85 Hypoid Gear Lube XY-75W85-QL WSS-M2C942-A
Rear axle fluid: Motorcraft® SAE 75W-85 Hypoid Gear Lube XY-75W85-QL WSS-M2C942-A
Transfer case fluid (U.S. and Mexico): Motorcraft® Transfer Case Fluid XT-10-QLVC WSS-M2C938-A MERCON® LV
Transfer case fluid (Canada): Motorcraft® Transfer Case Fluid CXT-10-LV12
16plati
VA
Dealership, I wouldn’t change unless you tow a ton or there’s a leak. Supposed to be good for like 100000 miles
16plati
VA
Clutch packs may be slipping on my 16 so I’m gonna do rear diff fluid change and friction modifier. 40000 miles...seems to be extremely common issue on these and f150s
PaulMedik
