PCV hose attachment location?
Discussion in 'General Discussion' started by archer59, Jun 28, 2006.
  1. archer59
    archer59 Member
    Jun 28, 2006
    Dumb question...
    1997 Exp with 5.4... where does the PCV hose connect to. Long story.
    Thanks,
    Nick
  2. archer59
    archer59 Member
    Jun 28, 2006
    Is the attachment location a secret???
  3. green03
    green03 Full Access Members
    634
    Apr 28, 2006
    College Station, TX
    It attaches to a manifold vacuum source
    Matt
  4. HI Expedition
    HI Expedition Member
    Jun 28, 2006
    I am having difficulty finding the location to the valve. I thought that it should be on the driver side valve cover, but that outlet is permanently attached.
    My fear is that the previous owner jb welded a plastic coupling in place of the pcv.
    I am getting codes for lean banks and having weak acceleration up hills occasionally.
    Does anyone have a picture of the place where the valve goes and a description of how to replace the valve?
  5. green03
    634
    Apr 28, 2006
    College Station, TX
    One side (valve cover) has a PCV valve and goes to a manifold vacuum source and is a smaller hose. The oposite side valve cover is the vent side and it should have a larger hose that hooks up between the mass air meter and throttle body.
    If you are getting a lean bank code the vent side is probably disconnected somehow and allowing unmetered air to enter the system between the mass air meter and the throttle body.
    Take a picture of the suspicious location for us if you can.
    Matt
  6. HI Expedition
    Jun 28, 2006
    I solved it. I was looking at the vent tube thinking that it was where the pcv was supposed to go because the other hole in the valve cover (passenger side) had a plug in it. After researching, I found out that the pcv was supposed to be on the passenger side. So I searched farther back on the cover for the pcv, and I found that it was not hooked up. It was hiding in some hoses. The previous owner must have lost it and replaced it with a plug.
    Now, I need to erase the codes and see if that was it. There are four codes, but I think this could have been responsible for all of them.
    Thanks for the response.
Share This Page
