PinStripe Removal
VexedEX
I was considering removing the pinstripe on the Expedition... I did this on my ranger mainly because it was pealing. The one on Expedition looks to be fine I'm just not sure I like it? Let me kknow what your opinion is? Thanks
sgtowing
Supporting Members
Valrico, Fl
That's up to you. Do what makes you happy.
Sent from my DROID BIONIC using Tapatalk 2
VexedEX
VexedEX
It's a sanding type tool.... Or I've heard people use hair dryers but that could take forever.... with the sanding tool you just have to be careful not to go too deep and scratch the paint.
VexedEX
VexedEX
Looks like this~
Hampton, VA
U don't need that...use a heat gun or hair blow dryer...put it on the pin stripe to heat up the glue...once u get it going...take ur time pulling...comes right off...don't need a stupid tool...lol...or just wait till its HOT out like I did...uses a blade to pull up a little piece and gently pull to remove...THATS IT!!!
Sent from my BlackBerry 9810 using Tapatalk
IAExpy
Cedar Rapids, Iowa
do you need to do anything to protect the paint under, or is the pinstripe over the clear coat?
VexedEX
VexedEX
It was a tool I borrowed from my brother when he worked at a paint shop. It is way easier but it's an 80 dollar tool. So Freeways idea would be less costly. When I removed the one off Ranger it didn't look bad. I removed The word EDGE with the tool as well and you could see a little bit of the word faded into the paint.
