I have a 2001 expedition rear wheel drive with 113k miles. it has what sounds like rumble strip noise but only at very slow speeds or accelerating from a stop and turning left or right. its worse when turning right.. I had a bad tie rod on one side and bad ball joint on other. I went ahead and changed all upper and lower ball joints and inner and outter tie rods. had alignment done. noise is still there. It seems to get a lot worse the more you drive it. So I'm assuming heat is making it worse. Any info would be greatly appreciated. thanks in advance
