George Menge
I purchased a 2006 Expedition Eddie Bauer addition with the 5.4 in it. It is running in Failsafe mode and the codes are for several sensors; throttle system, camshaft position sensors, turbine speed input sensor. I have replaced the tps, turbine speed sensor, and both camshaft sensors. I had the codes wiped clean and 2 blocks down the road it dropped back into failsafe mode. I returned to Oreilys and when they checked the codes... all the same codes popped up. The plugs all look good and the wires appear to be in good condition. I can only think the com is bad. Any suggestions or advice would be greatly appreciated.
Thank you
Thank you
