Radiator Engine Flush, New head gaskets, problem Oil in antifreeze.
Charles Musick
Va Beach
Looking for advise on flushing radiator/engine. I just put new head gaskets on so the oil problem is fixed
Looking for best product to use for oil in water/antifreeze. Should I wait or do it immediately? Even if I need to wait for some reason, I'll drain and put new antifreeze.
I want to do it now, provided it won't cause problems elsewhere.
stamp11127
Temple, Georgia
Well...... many people will laugh at this but... if it is just oil you want to remove and the rest of the cooling system is in good shape (no rust) we used to put Dawn dish detergent in and run it for a day, flush and fill with new coolant mix. If you have rust or scale buildup use a commercial cooling system cleaner.
Do not use tap water - only distilled water.
