Radio wire harness connection location.
Big Brian
Farmington Hills Mi
what about that black socket right above it?
does look like a radio connector but it could be anything...a manual would tell you
do you have power to the radio?
K
Koop57
Fredericksburg, va
The back of the radio is hooked up that goes from the wires that you hook the back of the radio into down into the ******* - because I changed out a heating core which means you have to take out your whole dash so I didn't unplug my radio I just unplugged all the ******* wire harness plugs and put my Dash in my backseat and when I came back to put it back in I couldn't see anywhere to put it so the back of my radio is perfectly fine and stock or aftermarket doesn't matter because they all plug into the same plugs behind the radio and go to that plug which plugs in somewhere else and I need to know that location
K
Koop57
Fredericksburg, va
The plug above it goes to my parking brake thing and I knew where that one was I just had to dash out when I took the picture. And everything else works but the radio I'm currently driving the car. It does not power up or anything like there's no power going to those wires because I need a home for that plug
Bedrck47
Elizebethtown, PA
No need for the language
But you didn't hook something back up so YOU need to find and fix the problem
That's not a factory unit I suggest you pull the radio and get a model number and the google it so you can see the wiring diagrams
BTW Since you need to know the location I SUGGEST YOU LOOK BEHIND THE DASH
Bedrck47
Elizebethtown, PA
ATTACHED ARE PRINTS OF ALL THE FACTORY WIRING BEHIND THE DASH
YOU SHOULD BE ABLE TO FIND WHAT YOU ARE LOOKING FOR WITH THESE PRINTS
  • 151-48.pdf
  • 151-49.pdf
  • 151-50.pdf
Big Brian
Farmington Hills Mi
hey I aint a mind reader just asking
throwing f bombs wont get you anywhere with me
I asked if the radio had power, you are assuming it doesn't, maybe something went wrong with the radio. If you dont have power at the radio trace it back like any other wiring problem, you dont know that that plug is related to the radio, you are just assuming it is
thats how I would handle it
Bedrck47
Elizebethtown, PA
FYI KNOWING IF ITS Stock or aftermarket does make a difference
You may have to remove the radio in order to find the factory connector that the aftermarket wiring needs to plug into
lbv150
Northeast
The factory radio takes two plugs one wire harness for the power and the other for the speakers.....
savbraze
