Rear Vent Windows
Discussion in '2nd Gen - 2003 - 2006' started by cml185, Jan 13, 2013.
  1. cml185
    cml185 New Member
    Dec 3, 2012
    ohio
    I have only had this beast for 4 months, and this forum may make me keep it for 10 more years. I have an 03 EB 4WD. The rear vent windows do nothing. Any idea where to start?
  2. Stoned06
    Stoned06 Full Access Members
    47
    997
    30
    Apr 2, 2008
    Milwaukee
    Fuse or bad motors would be a good start. If the fuse is good, put a multimeter on the motor connectors and see if they get power when switched on. If so, bad motors. If not, a short in the wiring or switch.
  3. amahay
    amahay Member
    Dec 12, 2010
    Kansas
    sometmes they just stick to the rubber trim. have someone push the button while you push out or gently twist the arm the moves the glass out.
  4. sgtowing
    sgtowing Super Mod, Supporting Members Supporting Member
    5,507
    367
    Jan 30, 2011
    Valrico, Fl
    Especially if they haven't been opened for a long time.
  5. cml185
    cml185 New Member
    Dec 3, 2012
    ohio
    Rear Vent Window help
    Thanks for all of the ideas! I will check it on Sat, as long as it is over 30 degrees!
  6. Ford Frank
    Ford Frank New Member
    Dec 27, 2014
    Oregon
    I just bought an 2003 EB. Its a stupid question, but how do these windows open? Are they power or manual?
  7. Bedrck47
    Bedrck47 Full Access Members
    4,182
    340
    Jul 4, 2014
    Elizebethtown, PA
    They are motorized
    If yours aren't working check fuse #22 with a meter
    Also check your owners manual for the location of the switch
  8. Ford Frank
    Dec 27, 2014
    Oregon
    I checked the manual again. Looks like the switch is next to the moon roof switch. Thanks!!!
  9. hendricksen11
    hendricksen11 Active Member
    42
    Jul 27, 2014
    Wallops Island, VA
    XLT doesn't have these :( That and keypad entry are the two things I wish our XLT had...
  10. 05expedeb
    05expedeb Full Access Members
    65
    Feb 23, 2015
    Medford NJ
    You could trade it in for a EB model
Share This Page
