Herb2017
All,
I have a 2006 Expedition 5.4. It was running very poorly, not responsive to acceleration, etc. Engine light came on, codes for sensor 1 on both bank 1 and 2. I replaced bank 2, sensor 1 but had a wiring problem issue on bank 1, sensor 1 and ended up taking it in and having a local place rewire it. I posted about it here.
After the rewire, it ran better than it had in months for about 2 days. On the 3rd day it basically reverted to the same poor running. At this point it's very difficult to even drive. It has the same behavior in that I need to really gun it to get accelerating and then level off when up to speed. But if I just 'normally' press the peddle to slowly gain speed, it will bog down and eventually the exhaust pipes will vibrate and shake making a loud noise.
THE CHECK ENGINE LIGHT IS NOT ON!!!! I put the cheap ODB2 unit I have on it and it doesn't detect any codes either. I'm not sure how it can be running so poorly and not have a check engine light on. It's been 3 days of this poor running without a code.
Does anyone have any idea of why the the check engine light isn't on? I can believe that the cheap ODB2 unit I have may not be able to do a professional job but does the lack of light say anything about the computer itself, not functioning properly, needs reset, anything? Does the described behavior suggest anything obvious? Fuel line, fuel filter comes to mind but it is the same behavior I had prior to getting the disconnected O2 sensor wiring fixed.
I'd like to get some opinions prior to taking it back in to the place that did the rewire since it's the first time I've used them.
Any guidance is appreciated.
Thanks in advance,
HB
Thanks in advance,
HB
