Exactly! ...and here we go again. To make long story short...installed HID ballasts, and bulbs for projector housing (low beams), but then high beams quit working...was tracing down wires tonight to run new circuit with relay to get high beams functional to pass inspection tomorrow. Anyway, in the process of doing this I noticed some white repair tape on my lower end coolant hose where it connects to the radiator.
Remember, this whole ordeal started with getting the radiator replaced in the first place. On my bill for the work done, I was charged for new upper and lower coolant lines. Apparently what that really means is "We put a new line up top, and then Eff'd up your lower line when we cut it off the old radiator because we didn't take the time to read the tag that says pull tab and twist. However, we wrapped some tape around it, and cleaned it with windex." I would actually be ok with this if they had really wrapped it, but nah, they just had enough tape on hand to patch it a bit. Now I have a coolant leak on the lower end.
From below looking up.
