Rusty rocker panel/door fix?
Discussion in 'How To Section' started by ICrushedAPrius, Feb 26, 2010.
  1. ICrushedAPrius
    ICrushedAPrius Full Access Members
    65
    Dec 28, 2009
    New Jersey
    Hi all,
    Quick question. I have a pretty bad rust problem with my rocker panels, wheel wells (fenders) and when you open the doors, the metal "step up." I am going to cut out the rust, grind it all down, and bondo/paint it. But I was noticing that most later model XLT/EB's have plastic fender molding, and plastic rocker panel trim that goes over these problem areas. Can I get these from anywhere for my 97 XLT? The paint won't match, and with the road salt in NJ, even my best fix will bubble quickly. I have seen some stainless steel rocker panel covers, but I rather have the stock Ford stuff.
    Any help would be great.
  2. tonydiv
    tonydiv technical advisor
    1,748
    127
    Sep 12, 2009
    Middle River, MD
    I just wanted to double check. You said that you were going to cut out the rust areas and fill it with bondo? You have to weld in new steel. Bondo is just for smoothing out any small areas.
    The one thing that I have learned about body work is that if you're not going to do it right, you may as well not bother at all.
  3. Remo
    Remo Full Access Members
    28
    545
    Jun 13, 2007
    Hartford, CT
    I'm getting rust on the bottom of the doors, too. Plus some showing on the rear quarter panels. Has anyone fixed these rust spots? What did you do to fix it?
    For rust on the frame, suspension, trailer hitch, etc I have used black Rustoleum paint. It seems to have stopped all the surface rust and is holding up okay for the last 2 yrs.
  4. Jay87LX
    Jay87LX Full Access Members
    507
    22
    Oct 2, 2011
    Cleveland oh
    Has anyone came across where to get the rocker panels and if so a link to supplier? I want to start gathering all the pasrts I am gonna need
  5. Nathanialson 08
    Nathanialson 08 Full Access Members
    491
    Sep 22, 2011
    Tooele Utah
    Check out www.lmctruck.com they started making replacement parts for the Ford Expedition first gens (1997-2002) and the second gens (2003-2006) and they make good quality products my dad bought parts from them to restore his 1961 ford F100 4x4, all the patch pannels and light rings and its quality stuff so check them out.
    Just showing you some of what they have plus good looking fender flares to help you make your fender trim look not overdone and close to a factory typ look.
  6. Jay87LX
    507
    22
    Oct 2, 2011
    Cleveland oh
    I just looked through their pages before I posted, Didn't see any rocker panels tho
  7. cleaningman94
    cleaningman94 Full Access Members
    296
    23
    Dec 2, 2011
    East Jordan Mi
    I read on another forum you have to order them for a f150 crew cab and do a little modification.
  8. TopGun
    TopGun Active Member
    37
    May 3, 2012
    Minneapolis
    Ive done the whole grind and weld dance with a side of new paint, only for it to get demolished in a Minnesota salt heavy winter. So im trying some new "experimental" fixes on my Expy this year. All else fails ill just get new doors. :)
  9. TopGun
    37
    May 3, 2012
    Minneapolis
  10. YoungKraze
    YoungKraze Well-Known Member
    47
    Feb 12, 2014
    CHICAGO IL
    You could get the Rocker Panels Of EBay For no more than $140
Share This Page
