So the Dealer said: "You Need a New Engine"
KeithP
This is about my 2009 5.4L (135K miles).
So, driving home from work, engine gets REAL rough, stumbling badly, and the engine light comes on. I take it directly to an autolab near my house for a quick scan for codes.
Yep, a P300 (random misfire), plus a P304 (misfire on 4). Hundreds of forums on this topic and many ways the story can go, but none like mine (that I've seen)..... which I am about to tell you.....
So, the troubleshooting begins...... I was pressed for time that night, so I paid the autolab to do a full diagnostic. Through the course of their diagnosis, the misfire codes increased to 303 and 308. They found nothing wrong with the airflow, or the COPS, and their conclusion was that the plugs were bad so their recommendation to me was to do a tune up. Now, they did not know that I had just gotten a tune up (plugs and fuel system clean and bunch of other regular maintenance) almost 1 year ago exactly by a Ford Dealer. Once I told them this, they were unsure what else it could be, but they recommended that I take it back to Dealer that did the tune up since I had 1 yr warranty. Before that, I asked them if they could do a cylinder compression test, but they did not have the right adapter to do this. (I was a little bothered about this, but later found out that it is VERY difficult to get your hands on a compression tester that has an adapter that fit into Ford's 5.4L 3V spark plug bore). So I paid them the 100 bucks diagnostic fee and took it over to the Ford Dealer that did my tune up.
The Ford Dealer basically told me that I would have to pay them to do a diagnostic even after I described my issue and after they verified the work that I had done their last year... they did confirm that the plugs were under warranty and if plugs were found to be the issue, they would be covered.
So, I reluctantly went forward with another diagnosis. But the customer service rep said "at least here at the dealer we have 'specialized equipment' to check the cylinders". I later found out that they don't do a traditional compression test on cylinders, they now do what's called a power balance test with their scan tools.....
Anyway, so I get a voice mail the next day from the service guy....."Hey it's me.....from Ford.... unfortunately it looks like your gonna need some engine work...... please call back......"
So I call the guy back and he says very casually...... "Yeah, you got engine failure, your #4 cylinder is completely dead. You need a new engine"..... To which I ask, "say what?.....a new engine? that's expensive isn't it?"..... to which he replies (again very casually)...."Yeah, it's about 8 Grand..... so, do you want us to order it?"........ I just laughed sarcastically and hung up.....
After I cooled off I called the guy back and told him I would just pick it up.... no way in hell I'm gonna pay a dealer that kind of money for a new engine. You can get a re-man for about $3000-$3500 and most sellers will help you find a reliable place to install it. I was thinking $4,500 worst case, or maybe just push the old girl into a river..... but I wasn't gonna do that, she's in really nice shape.
Now, fortunately, I have some totally awesome friends and relatives which I shared my experience. They love this kind of stuff, so they offered their help, and they assured me that there was "NO WAY I needed a NEW ENGINE!!!!". They came over and started troubleshooting and diagnosing, looking at you tube and forums, etc... at one point, my buddy starts feeling the intake and notices it's VERY hot in the back (right over top of #4!). He deduces that there's a valve issue at bank #4 and that the exhaust is blowing back up into the intake making it hot and causing the misfire. Now bank 3 and 8 (which also were throwing mis-fire codes) are adjacent to 4, so he goes on to deduce that the exhaust blow back is crossing over to the those 2 banks causing them to misfire......
So, we start making plans to go as far as pulling off the head on the passenger side thinking we'll get it machined and replace any damaged parts. I was pleasantly surprised that it wasn't very difficult and there wasn't too much to pull out of the engine compartment to get access to pull the valve cover off the passenger side. Once the intake was out, there was plenty of access.
To our amazement, as soon as the valve cover came off, one of my buddies immediately points and says, "hey look, you got a broken spring".....
A BROKEN SPRING!!!!! NO Kidding!! A 4 DOLLAR SPRING!!!!! Can you believe that?..... OK, I could go on and share with you some of the calamity that occurred while replacing that spring, it wasn't a completely simple task because thanks to Ford it took a very very special tool to remove the old broken one and install the new one (which we spent days tracking one down), but I will spare you that. I was also lucky that the valve and stem was not bent. The good news, with spring replaced and putting all back together, a few new gaskets, new plugs (yeah, went ahead and replaced 'em all again since 3 of them were fouled out from the exhaust), at the expense of a couple nights in my garage with my buddies and about 100 bucks worth of parts/cleaner/fresh coolant and miscellaneous..... all went well and we are running smoothly!
Now, you've read my story, and my only question to all you fine folks..... what would you say to the guy at the Dealer that told me I needed a new engine for $8000?
reece146
ON, Canada
Yeah, a lot of dealers are the absolute worst place to get a vehicle diag. If it doesn't fit a normal wear item replacement pattern on a newish vehicle they are lost it seems.
Sad but that's been my experience. Local dealer tried to get me to do a $2K timing chain replacement on my A4. Indy shop fixed the real issue and it's been great since.
stamp11127
Temple, Georgia
Well, that is the state of knowledge today. Since the advent of the gaming console and portable phones the kids of today don't read. They have to watch videos now. Therefore they don't learn as well as their parents. So the scan tool the "mechanics" use is now "god" and the art of diagnosis is becoming a thing of the past.
Flexpedition
midwest
Isn't Auto Lab's registered trademark "We Test...Not Guess"? And for $100 they guessed bad plugs? And they get to keep your money?
Its only difficult to get a 5.4L 3V compression tester adapter if you live in an area where they have no FedEx, no UPS, no DHL and only bi-weekly USPS mail. Or if you live where there is no Snap-On, Cornwell, Matco or Mac tool trucks. Or very far from Sears, O'Reillys, Autozone, NAPA, Checkers. 3V has been around since atleast 2003 and was super common on Americas best selling vehicle for 30+ years.
If you feel like you need to share this with the dealer, tell them you found a broken spring. Since its not a common failure, maybe he'd be interested. Tell Auto Lab too, after your refund.
jeff kushner
North of Annapolis
Unfortunately, Stamp is right....the dealers now hire "parts changers" and many understand even what true mechanics would call "basic engine fundamentals". I don't know too many real mechanics who would have made a "Catastrophic engine failure" diagnosis based on a computer readout without even the most basic of a compression test on the offending cylinder.
Thankfully, your instincts were spot-on and you were smart enough to reach out to others but think about all those people who by their own lack of knowledge or lack of critical thinking ability, are forced to accept those irresponsible diagnosis without question......while I'm sorry that you got a BS estimate...the ones I really feel sorry for are the ones too ignorant to know that they are being lead around by the nose!
Get a second opinion doesn't relate just to medical stuff anymore!
Thanks for posting!
jeff
bear1butt
US
Not sure if im in rite place but mayb some one can direct me to it. My prob is a 99 expedition 4.6 was running fone then going down road lost #1 and #4 cylinders. Dead miss. Compression low on 3 cylinders that bank. Head gasket?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Bedrck47
Elizebethtown, PA
Welcome to the forum
You would be better off to post a new thread in either the 1st gen section or the engine section dealing with your problem rather in posting in someone else's thread. You will get better results that way
Mr67Stang
Tennessee
Most dealer service departments and regular shops for that matter do not have "mechanics" working for them. They are simply "parts replacers". Sure, it would have fixed your problem, but they just do not have the knowhow to actually repair anything.
rollinstone
Seattle
Once I could not adjust my heater temp. Dealer said I needed a new plenum and other heater components...$1200-$1500. I fixed it for $17 when I discovered it was just a broken blend door hinge.
