Squeaky Bushings
Discussion in 'General Discussion' started by mic_1011, Mar 11, 2010.
  1. mic_1011
    mic_1011 Full Access Members
    96
    Jan 16, 2010
    yonkers n.y.
    my bushings are squeaky squeky on my 98 eb and it's driving me crazy. i hate mechanics so i've learned to do alot of my own work. anyone know how hard it is to change bushings? Any info is greatly appreciated
  2. 98_XLT
    98_XLT New Member
    Mar 8, 2010
    Where abouts is it coming from?
    I have a bad 'creak' on my 98 but I think I have narrowed it down to the Pitman arm or the Idler arm.
  3. nvycrmn
    nvycrmn Full Access Members
    1,631
    Feb 15, 2010
    Springville, IA
    if its the bushings in the shocks, they arent too hard to do. just unbolt the shocks, use a vice to push out the old bushings and insert the new ones. just about that simple. bushings are pretty cheap
  4. KWT2000
    KWT2000 Full Access Members
    2,376
    34
    Feb 4, 2010
    NINE MILE FALLS
    if you still the factory ball joints and tie rods and such they dont have grease zerks and get dry over time and squeak when you turn or hit speed bumps... i got a grease needle for my grase gun $3 that allows me to grease the joints and solved my squeaking front end
  5. mic_1011
    96
    Jan 16, 2010
    yonkers n.y.
    i know its the front end, i've even laid under it and pushed it up and down to try to pinpoint it but i still can't call it. i had the control arms changed in 05 but the bushings look pretty dry and the ball joint at the end of the control arm is all tore up. i was looking at the energy suspension kit, $100. what do you guys think? are they hard to change?
  6. KWT2000
    2,376
    34
    Feb 4, 2010
    NINE MILE FALLS
    i have the energy suspension control arm bushings on my 97 the handleing difference was night and day.... it took me about 6 hours to install them
  7. mic_1011
    96
    Jan 16, 2010
    yonkers n.y.
    that sounds great! i'm gonna get them this week. we're supposed to be hitting 60's this week. i can do it on the weekend. any pointers? how did you manage to remove the old bushings and install the new ones. do i need any special tools?
  8. KWT2000
    2,376
    34
    Feb 4, 2010
    NINE MILE FALLS
    the most time consuming for was getting the torsion bars out, 13 years of grit took its toll... i have a ball joint/ u-joint service tool with the master adapter set. both kits are about $100 at harbor freight... thats what i used to press the bushings in and out. or you can pull the control arms off and have a shop press the bushings for you... the night before i would spray all the nuts and bolts with a good penetrating oil. too load and unload the torsion keys i use a 2 jaw puller... hope this helps you out
Share This Page
