Sticky worthy??? Quick fix for rear wiper motor turning but not moving wiper arm
darmahsd
Wilton, NY
Maybe you guys in warmer climates don't need them, but they're essential up here. This is a fix for 1rst gen. 2nd gen's have their own problem. My '05's pivot bearing is seized. Motor's fine, but need to find better bearings when I see this thing apart. My 1rst gen '97 never had a rear wiper problem in the 225k that I had it. I also never had to assist the "power" windows by pulling up with my hands when -8 degrees like I did with my '05 this morning.
darmahsd
Wilton, NY
Fixing siezed rear wiper mechanism on 2nd gen and up.
Moisture seeps through the "O" ring on the shaft between the arm and housing on 2nd gen rear wiper mechanism.
White metal housing that wiper shaft goes through swells up with
corrosion, seizing the shaft. Ford probably didn't put adequate lubrication from new. Bronze bushing is usually OK. Remove "C" clip to take mechanism apart after removing wiper arm shaft nut and two nuts holding mechanism to glued in plate on rear hatch glass.
After removing corrosion from shaft housing I pack in a water resistant red grease containing silicone that is used for the sliding pins on brake calipers. It's called "Siliglide". For good measure, the "O" ring, if not damaged, gets the grease and extra "O" rings are added OUTSIDE the big nut before the wiper arm is attached.
They're not going anywhere and will help keep moisture out of the
housing. A bad execution of the rear wiper design by Ford, IMHO. The
1rst gen rear wiper was more complicated and expensive to
manufacture, but for me, was more reliable than this one. Haven't had
any issues since rebuilding mine. Occasional usage will probably keep it from siezing again. With this design, I think not using it may allow it to freeze up faster. Do it to yours instead of wasting over $80 on a new mechanism.
whitelightning99
Pa
i think i may try this my rear sprayer works but wiper does not BUT i can not figure out how the dam wiper blades come off to save my ass,i don't want to break them like i have on my last two trucks hehe someone explain please that goes for the windshield wiper to
Habbibie
Is it Christmas yet?
Chicago
So you could do this
Took back wheels off today,Took calibers and rotors off cleaned and sprayed all the moving parts in there very little bit of wd-40 got the e brake cable and stuff to work better still sucks though lol. BUT found the right rear axle seal has been leaking for some time every things caked and soaked with gear oil.So axle seal will be needing to be replaced uggg
But you can't take a wiper blade off?? That's "odd"
whitelightning99
Pa
yea it's about as ODD as your Rainbow avatar pshhh *****
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
Mine works, but it's pretty worthless as it wipes all over the place. The gate only... part gate part window... The passenger side gate... pretty much wherever it wants to but usually NOT the actual window itself.
:Rant:
TactialMonkey
Washington
I gave up on mine i took mine out and the motor just stuck a plug in it from the inside some lock tight and then plastidipped it the rest of the trucks color... granted mines a white trash warrior wheels build but she runs and drives when I wanna take her out
Sent from my SAMSUNG-SM-G890A using Tapatalk
whitelightning99
Pa
I took my wiper arm off didn't want it to start working all of a sudden with a junk wiper blade on there and f my back window up.i'll be getting few other wiper motors cause i am getting power to the plug that plug into it.be nice to actually see it work an do it's job hehe
