stock to HID?
lxrick
Germany
I like these, they are looking very good:
http://www.ebay.com/itm/Smoke-2007-...ash=item58d6d68498:g:7M0AAOSwv9hW2h9i&vxp=mtr
In addition all you need is a common H1-bulb HID conversion Kit with 5000k (that´s blue enough for adult eyes!) and to do some plug and play wiring.
http://www.ebay.com/itm/Xentec-35W-...m33a1fad3a7:m:m0ESKeJOXNUT_-3IknNLzWQ&vxp=mtr
btw, as you can see in my profile picture, I had the stock Headlights with HID. And YES as state above, it is bulls...!
So I switched to projectors and in addition I retrofittet BMW 7 Series lenses (E38 1995-2004) systems for "standard" Osram-Xenarc-D2S-Nightbreaker-Blue-Intense bulbs. Now it is how it always should have been from the start. But that was a lot of work.
I am sure the new Headlights above with a standard HID conversion Kit will solve all your problems too.
Good luck, Alex
gixer2000
Retrofit or Bust
Massachusetts
id strongly recommend doing a legit retrofit and customize them however you like. here's the ones i did. Very simple and plain but put good light in front of me without blinding oncoming traffic
lxrick
Germany
OK, this is nice but a little bit insane.
Why didn´t you bought some Projection Aftermarket Headlights and simply changed the Lens systems from behind?!? With Premium Lenses from Hella, Valeo with original Osram or Philips D2S Bulbs?!?
Nothing really big had to be changed and I still have the original Headlights in case of selling the car or whatever...
But hey...good work! :)
gixer2000
Retrofit or Bust
Massachusetts
The aftermarket housing require more work to get a quality projector mounted and aligned then the stock lenses do. Plus they are made from cheap materials so even if a get a good projector in there I'm still stuck with a housing that just looks cheap and clearly aftermarket. The goal for me was to get premium lighting but have it look factory as possible.
USMCBuckWild
Camp LeJeune, NC
gixer2000
Retrofit or Bust
Massachusetts
This is the exact look and performance specs I want!
Can we get a parts list?
It's in your inbox and I added it to the media for anyone else that's interested. Also if you already have and HID kit you could use the ballasts you just need H1 bulbs to fit the projector
rwmorrisonjr
Memphis, TN
I did a complete Motimoto DS2 HID projector retrofit into the stock housings, and they look factory. Great light pattern, and able to be aimed properly, so no blinding anyone. I've attached some pics: off and on. The "on" pic looks like a HID bulb only, but its not. I'll get some better pics when its not raining and I can be outside my garage. IMG_0297.JPG
It looks like the same retrofit that gixer2000 did.
EL Expedition
Albuquerque
I have a set of 09 limited headlights with Morimoto D2s projectors with ballasts. Wife did not like them so I put the stock lights back in. I installed some custom backlighting that shines on the reflectors and looks pretty cool with just the driving lights on. See the pics in my gallery. I will take $450 shipped. They will need to be tuned, before I took them off they were a little off.
