Sudden weak performance from keyless entry
Discussion in 'Audio & Electronics' started by Dwilds, May 14, 2018.
  1. Dwilds
    Dwilds Member
    Jun 2, 2016
    St Petersburg FL
    Hello all. Noticed over the last couple days that the keyless entry range has weakened significantly on my 2003 Expedition XLT. The range had already been less for the last few years than when we bought new but now most of the time the key fobs won’t work at all. Just recently in the last 3 days I purchased some additional keyfobs off amazon and they worked just as well as the older ones for a couple days. Now they work only once in awhile. Does anyone know how to troubleshoot this issue? Is there an antenna I can check or a connection that may have gone bad?
  2. Trainmaster
    Trainmaster Full Access Members
    52
    193
    88
    Jun 17, 2017
    Rockaway Beach, NY
    My experience is that the remotes, especially counterfeit ones, degrade. At times changing the battery helps, but more often it does nothing. Replacement remotes are often Chinese knockoffs that work poorly. I was so fed up with poor range, undependable operation and buttons that sometimes didn't quite work that I ordered a Ford OEM replacement at ten times the price of the knock offs. It solved my problem and the thing works as it should again.
  3. Habbibie
    Habbibie Legendary Member
    1,294
    325
    Feb 2, 2016
    Chicago's NW burbs
    My previous employer's issued 2014 F150 suffered from this, it pissed me off that I had to be within 10ft of the truck maximum for the key fob to work, an OEM reciever module and a new programmed key (key fob is part of the switch) did not even remotely improve it,
Share This Page
