Suspension Torque Specifications
Discussion in 'Suspension' started by Jackmldog, Mar 6, 2011.
  1. Jackmldog
    Jackmldog Full Access Members
    85
    Aug 17, 2010
    Mobile,AL / Baton Rouge,LA
    One ft-lb of torque is equivalent to 12 in-lbs. The below values are all in ft-lb unless otherwise stated. Hope this helps some people who don't have manuals.
    Front Suspension
    Air Shock
    --Lower bolt/nut
    ---2003 and earlier models: 56 to 76
    ---2004 and 2005 models: 293
    ---2006 and later models: 350
    --Upper nut: 37 to 44
    Balljoints
    --Lower balljoint to knuckle nut: 83 to 112
    --Upper balljoint to knuckle nut: 57 to 76
    Lower control arm to frame pivot bolts/nuts
    --2003 and earlier models: 197 to 241
    --2004 through 2006 models: 199
    --2007 and later models: 256
    Shock absorber
    --Lower nuts (2WD): 22 to 29
    --Lower bolt/nut (4WD)
    ---1999 and earlier models: 56 to 76
    ---2000 and later models: 65 to 87
    --Upper nut: 35 to 46
    Sway Bar
    --Bracket to frame bolts: 19 to 25
    --Link nut: 16 to 21
    Upper Control arm to frame picot bolt nuts: 83 to 112
    Hub and bearing assembly bolts: 110 to 148
    Rear Suspension
    Lower control arm to frame nuts
    --2003 through 2006 models: 184
    --2007 and 2008 models: 221
    --2009 and later models: 266
    Lower control arm to knuckle nut
    --2003 through 2006 models: 295
    --2007 and 2008 models: 350
    --2009 and later models: 406
    Upper control arm to frame
    ---Forward nut: 111
    ---Rearward nut: 184
    --2009 and later models: 165
    Upper control arm to knuckle nut
    --2003 through 2006 models: 111
    --2007 and later models: 76
    Trailing arms (2007 and later models)
    --Lower trailing arm to frame: 203
    --Lower trailing arm to knuckle: 76
    --Upper trailing arm to frame: 203
    --Upper trailing arm to knuckle
    ---Bolt: 184
    ---Nut: 76
    Shock absorber mounting bolt 2002 and earlier (lower and upper): 63 to 84
    Shock absorber/spring assembly upper mounting nuts 2003 and later: 24
    Shock absorber/spring lower mounting bolt
    --2003 models: 350
    --2004 and 2005 models: 332
    --2006 models: 295
    -- 2007 and later models: 406
    Shock Rod nut
    --2003 through 2006 models: 22
    --2007 and later models: 41
    Stabilizer bar link nuts
    --2002 and earlier models: 63 to 84
    --2003 through 2005 models: 66
    --2006 models: 59
    --2007 and later models: 46
    Stabilizer bar bushing bracket nuts
    --2003 through 2005 models: 30
    --2006 models: 41
    --2007 and later models: 35
    Toe link to frame nut
    --2003 and 2004 models: 59
    --2005 models: 66
    --2006 models: 52
    --2007 and later models: 203
    Toe link to knuckle bolt or nut
    --2003 through 2006 models: 41
    --2007 and later models: 165
    Toe link adjuster lock nut: 85
    Wheel bearing/hub assembly mounting bolts
    --2003 through 2008 models: 136
    --2009 and later models: 129
    Steering
    Airbag module retaining screws: 89 to 115 in-lbs
    Idler arm
    --Idler arm bracket to frame bolts: 125 to 169
    --Idler arm to center link ballstud nut: 56 to 75
    Intermediate shaft to steering gear input shaft pinch bolt: 30 to 40
    Pitman arm
    --Pitman arm to steering gear nut: 173 to 233
    --Pitman arm to center link ballstud nut: 56 to 75
    Power Steering pump mounting bolts: 15 to 20
    Steering gear to frame mounting bolts
    --2002 and earlier: 50 to 67
    --2003 to 2006 models: 11
    --2007 and later models: 325
    Steering wheel bolt: 23 to 32
    Tie Rod Ends
    --Inner tie rod end to center link ballstud nut: 56 to 75
    --Outer tie rod end to steering knuckle ballstud nut: 56 to 75
    GalaxyPilot likes this.
  2. GXPY
    GXPY Member
    16
    Mar 30, 2010
    Sparks, Nevada
    Awesome, going to install the lift on my '09 Friday and was in desperate need of torque specs. Thank you!
  3. 98EXPY 5-0
    98EXPY 5-0 Full Access Members
    553
    Jul 25, 2009
    PA
    Do you have the torque numbers for lower and up upper trailing arms bolts for my 2000?
  4. GalaxyPilot
    GalaxyPilot Active Member
    29
    Jun 8, 2014
    Enid,OK
    So when there's a range, is there anything that dictates how high you go?
Share This Page
