Alright,
first noticed my 99 EB with 2WD was struggling to climb hills, the engine would increase RPM, but the power output just seemed flat. This would also happen on leveled surfaces too sometimes, depending on how I launch the vehicle from a standstill. This all really felt like a failing torque converter, like the impeller or stater fins were running flat or broken loose. It really felt like the power was being totally lost at the transmission, but not in the direct gearing, or any of the drive clutches, just at the torque converter. Then, after some basic google research, I was informed of the throttle position sensor, which made a lot more sense to me.
As some of you can already see where this is going, I managed to strip the bottom screw which holds the sensor in place. This is a very common issue with many ford vehicles. I can't imagine why none of this turned up in everything I researched about replacing the TPS. Absolutely no warnings about these screws which are practically welded on the throttle-body. The official service manual does not even give proper procedure in removing this. You absolutely must remove the assembly which holds some kind of EGR valve or EVAP doo-hickey and there is some other related tubing connected to those things, and the official service manual mentions nothing of this. None of the Youtube videos warn of the stuck screws either. Very frustrating!
Anyway, I would like to know more about this component. There is simply not enough information here regarding all aspects of it.
How does this component fail? There seems to be no moving parts, and judging by looks alone, it seems to use magnetism to detect the position of the TB.
Also - mounting. Does the surface need to be clean? I hardly loosened the top screw, maybe a half turn, and I am getting bursts of high idle and fault code/CEL for the TPS, also the transmission doesn't know when to shift gears anymore! I am certain the PCM uses the TPS signal to also control the transmission!
This component seems very delicate, so mounting it must have special procedure of some sort. Some kind of additional info here would be much appreciated.
I am also considering the connector for the TPS too, my chinese multimeter broke a probe, so I cannot even test the TPS or its connection.
