Alright ladies,
I never bothered to take photos of anything because everyting was new to me and was excited to put the truck back together once I was finished.
But here is a photo of the job.
Keep in mind this is my very first work ever done to my own vehicle!
Replacing the Throttle Position Sensor is absolutely mandatory. If you haven't done so yet, do it now.
You may think your vehicle is working properly, but it's not. It will slowly adapt to the failing TPS and you will not notice an issue until it becomes much worse. Typically the Throttle Position Sensor will still function even at 40-50% effectiveness, which is exactly what you don't want! And they degrade quickly. They reach this un-optimal state very quickly, (within a couple of years, depending on how you drive, specifically on how hot your engine gets)
Your transmission relies on this cheap component to function properly, and it's also suspected this component can contribute to the demise of your automatic transmission.
Anyway, these screws are welded on. It's crazy. They are really glued in there.
I had to cut out a slot within the screw using a rotary tool and cut-off-wheel.
The cut is perfectly centered, you can use the original phillips head as a guide.
I had a giant 18inch flat head screwdriver stuck in there, with the entire throttle body removed.
Even with the giant screwdriver, and perfect leverage, it absolutely took all my strength to remove it. Crazy! The giant flat head screwdriver fit absolutely perfect, it wasn't loose or anything.
This damn screw is wayyyyy too tight, I would never expect anything to be mounted this way!
