StephanSloan
Just finished installing new brake rotors and pads on my 2008 Expedition EL (145,000 miles).
I bled the system thoroughly using the "Pump the pedal-crack the bleeder" method. The old brake fluid was tan in color and I bled until the lighter new fluid was pumping through. I did not notice any air bubbles or foam.
The pedal is still lower and a little softer than I would like, not bad, just not great.
Is there a way to bleed the ABS system myself or any other suggestions?
Thanks
Thanks
