Colorado Joe
I have a 2006 Expy Limited that is having problems with the autoride suspension system. I've had it in the dealership to diagnose and correct the problem but they aren't able to (or don't want to) find the problem and fix it. I have one side that raises up and will not lower until the temps warm up, this only happens at temps lower than 35 degrees and here in Colorado that's most of the next 6 months. I also have the rear left corner that is stubborn and does it as soon as it get cold.
Has anyone experienced anything like this? they've replaced the two front ride height sensors and have checked the back two which according to them is fine. They are sure it doesn't have leaks since it holds air when it's warm and all works fine. I was told by the dealership that it could run up to $6,000.00 to chase and find the problem. I really like the Autoride system when it's working. it's smooth as glass and the load capacity is great. I would really like to keep the system as is but need to find a reputable shop here in Denver Colorado that can find and fix the problem without paying a kings ransom.
I have a couple of questions, does anyone have a reasonably sure answer as to what this might be? if not does anyone have the name of a shop that can take care of the problem?
The second question is, if I do a conversion as a last resort is there one kit that is better than the others keeping in mind ride comfort, good road characteristics (not top heavy feeling or leaning into turns) and still keeping the towing weight at manufacturer specs? This has just made me want to go out and get rid of the vehicle if I'm just going to continue having suspension issues. I really love the car when it's working correctly but winter is here and the problems just continue. HELP PLEASE!!!
