Towing Package
Discussion in 'Towing & Hauling' started by 5.4 Shelby, Dec 31, 2009.
  1. 5.4 Shelby
    5.4 Shelby New Member
    Dec 31, 2009
    Indiana
    How do you know if you have the towing package? Door sticker? does the radiator look different?
    Door sticker says ( I think) 7700 lbs. GVRW. The towing package is supposed to be over 9000, right?
    i looked and don't see a tranny or oil cooler. Should if be obvious?
    Edit: Looking at a 2008 Expy Limited.
  2. Franklie
    Franklie Well-Known Member
    46
    Nov 25, 2009
    Dallas
  3. 5.4 Shelby
    Dec 31, 2009
    Indiana
    Thank you Franklie. Appreciate the help.
    I am about to buy a 2008 Limited. The dealer says it has the towing package. I don't see a separate oil cooler. It could be intergrated in the main radiator, but, I can't tell. That is why I started this post. I was hoping someone could say whether or not I should see a difference or could tell from the door sticker or maybe some other way.
    If it does not come with it, does adding a tranny/oil cooler bring it up to the 9000lb towing capacity?
    I am planning to occasionally tow my '08 Mustang in an enclosed trailer. With the car weighing nearly 3900lb dry, I am afraid I would be pushing the limit.
  4. chevy24d
    chevy24d Full Access Members
    57
    Dec 2, 2007
    Orange, CT
    I posted this on fte for you. Search my user-name and there is a ton of info on trailer packages.
    https://www.fleet.ford.com/showroom/rv_trailer_towing/2008/2008_default.asp
  5. 5.4 Shelby
    Dec 31, 2009
    Indiana
    Thanx 24. I didnt quite get the answer on here so i searched for and found FTE. My how to identify has been answered on there. If it has the HD tow pkg, it has the 7 pin connector on the right side of the hitch. I plan to go to dealer in the next day or 2 to check that.
    My question about "can it be upgraded?" has not been answered. So far it seems like I would have to replace the entire radiator and add the 7 pin connector. But I don't know if that will bring me up to 9200.
    I will search for you on FTE.
  6. z168
    z168 Full Access Members
    470
    30
    Sep 26, 2009
    Cali
    on a 2000 Expy, how can you tell?
  7. gjhanson2
    gjhanson2 Full Access Members
    76
    Jan 13, 2010
    Orange County, CA
    For the 2000, I believe it's the same as my 99, look for a separate trans cooler and air suspension in the rear if it's a 4x2.
  8. rick chitown
    rick chitown Full Access Members
    140
    Dec 28, 2009
    Illinois
    What is this FTE you speak of? Is there a website?
  9. AndyGJ
    AndyGJ Active Member
    33
    Feb 1, 2010
    Atlanta
    Let me guess...that 5.4 is an 08 Shelby.
    Are you on the Team Shelby forum?
  10. jimmyv13
    jimmyv13 Full Access Members
    89
    Sep 13, 2009
    Assuming you're referring to the heave duty towing package, the 7 pin connector along with the 4 pin flat connector next to the hitch is a dead giveaway, the HD pkg comes with both, the standard towing only comes with the 4 pin. Of course, the HD pkg has the above mentioned items as well, but it's very easy to look at the back to see if the round connector is there.
Share This Page
