Towing Question
Joseph Seda
Yuma AZ
I have a 97 expedition Eddie Bauer with the 5.4 and a 3.31 ratio. I’m planning on towing a sedan on a U-Haul trailer from Arizona to Florida. How do you think it will do? Any tips?
1955moose
You should be fine, just be sure to check all three fluids, oil/coolant/ and most important trans fluid. Don't strain engine at high speeds, 55 mph is max anyway with trailer. Leave overdrive off on any grades.
1997SCEBFEX
Northwest Panhandle
++ on what Moose said.
I manually shifted mine on steep grades and held rpms to 3500. I upgraded my trans pan (mag-hytec) and it holds and extra 8 qts.
cruise control may act weird as it tries to compensate.
you may want trailering mirrors?
do you have air suspension?
here's a checklist I use; some items may be N/A for you.
View media item 4165
J
Joseph Seda
Yuma AZ
I do have air suspension. I was also thinking of adding a trans cooler. How does the air suspension compare with the passive coil over suspension conversion
and0r
CA
doesn't the expedition 5.4 come with a trans cooler? is there some kind of factory tow package which would include such thing? pretty sure my 99 EB has a trans cooler
J
Joseph Seda
Yuma AZ
I’m not sure I’d have to check. I bought it a couple days ago for this trip. Its got 170k miles on it. Just wanting to make sure I’m all set before taking it cross country towing a vehicle
johnboneske
Ohio
Its just fine, the 5.4's have a trans cooler built in the radiator. I had a 97 XLT and it towed wonderfully! I towed a car(Taurus SHO) on a Uhaul trailer from Wisconsin to Ohio, left it in Overdrive and towed around 65 to 70 MPH, I got about 9.5 MPG, which in my opinion was good since the best I ever got was 12.78 on one trip solo. Mine had 3.73 gears though, so the 3.31's may be a little "sluggish". Just my $.02.
1997SCEBFEX
Northwest Panhandle
deactivate your air suspension, load everything up, reactivate it so it can settle out.
5.4's w/towing package have trans cooler separately dedicated.
toomanytoys
The cooler that’s built into the radiator is NOT a trans cooler. Trans coolers are separate in the fluid circuit. I’ve towed my grand national on a uhaul full sized trailer with no issues. Did 65-70 mph and got 11-12 mpg. The only thing that sucks is the surge brake on the trailer. And like was stated before take it out of OD when going up hill and you’ll be fine
