Trailer lights won't work
BigJay
Alabama
I've installed a new trailer wiring harness for my small motorcycle trailer, 4-pin. I tried connecting it to the factory 4-pin receptacle and a 7-pin adapter. Neither activate the lights on the trailer. Any suggestions?
Bedrck47
Elizebethtown, PA
If your factory 7 pin worked correctly then the factory 4 pin should also be correct
I would suspect a bad ground or a mis-wired connector on the trailer
Can you read and understand wiring diagrams
Also do you have a volt meter
BigJay
BigJay
Alabama
i can, I'm an engineer; my electrician buddy is bringing his meter.
thanks
Bedrck47
Elizebethtown, PA
prints for the 2010 attached
Let me know how you make out
  • 2010 Trailer Tow.pdf
