The following was copied from the 2004 service manual
General Specifications
Item Specification
Fluid
- These dual-usage fluids are not to be used in transmissions that use only the MERCON® type fluid. These dual-usage fluids may be used in transmissions that require MERCON V® use.
- Use of any fluid other than the recommended fluid may cause transmission damage.
- Refer to the transmission fluid level indicator and the Owner's Guide for the correct type of transmission fluid required. Some fluid labels may indicate dual usage such as MERCON® and MERCON V®.
- Using a transmission fluid that indicates a dual usage MERCON ® and MERCON V® in a transmission application requiring MERCON®, may cause transmission damage.
Motorcraft MERCON® Multipurpose (ATF) Transmission Fluid XT-2-QDX MERCON®
Fluid Capacities
- The fluid capacities are approximate dry fill capacity and include fluid coolers and fluid cooler tubes.
- Fluid level indicator should be used to determine actual fluid requirement and fluid specifications.
- Check level at operating temperature. DO NOT OVERFILL.
- The transmission fluid and the in-line filter should be changed every 30,000 miles (48,000 km) regardless of normal or special operating conditions.
4R100 4x2 15.0L (15.9 Quarts) Approximately Dry Fill Capacity
4R100 4x4 15.5L (15.9 Quarts) Approximately Dry Fill Capacity
Transmission Fluid In-Line Filter
Transmission Fluid In-Line Filter Kit XC3Z-7B155-AA
Transmission Fluid In-Line Filter XC3Z-7B155-BA
Lubricants
Silicone Brake Caliper Grease and Dielectric Compound
D7AZ-19A331-A (Motorcraft WA-10) ESE-M1C171-A
Multi-Purpose Grease
D0AZ-19584-AA ESB-M1C93-B
