juan214
I had planned to change my tranny fluid on my truck once I was done with my wife's van repairs. As far as I know it's never been changed. It does leak or loses tranny fluid have to put some in every few weeks. She leaks or burns oil too. I'd like to track down the leaks one at a if possible. Any suggestions?
Anyway haven't use the truck in about two weeks until I needed to go get parts. I have developed a noise loud at start up the quiets down after a bit. I got under it and took the inspection plate off. It's dry in there from what I can tell. From what I could see the first bolt looked tight I tried to move the converter and flywheel forward and backwards to check for movement (none). Inspected for loose parts around the area and cleaned up the area with parts cleaner and wiped it down. Found a heat shield loose on a Catalytic converter (not part of this issue). Started the truck got under it quieted down by the time I got under it. Looked at the flywheel spinning no visual movement. Used my stethoscope everywhere top to bottom, front to back. Noise seems louder at the bellhousing one inch away at the pans it's quieter. No loud top or bottom end noises. I'm assuming it's either the flywheel or the torque converter. Any suggestions to further diagnose this?
Thinking about tightening the nuts down to check torque. Need torque spec for nut to conveter.
Fluid last used to top off Castrol Transmax® MERCON V Certified for use in Ford vehicles that require Mercon or Mercon V.
Correct me where I'm wrong.
I took it out for a test ride around the block. Noise goes away when driving and she shifts fine at it's usual points at about 1800 rpm give or take a few hundred.
- 4R100 transmission.
- Mercon / Mercon V
- How many quarts?
- Flush or Changed?
