98 5.4
I'll start from the beginning.
Battery kept dying bought a new one. And I did not drive the truck too often but would start every week. Then the new battery kept dying had it tested and it was okay guy said it has around 11v (but would not start the truck) had my alternator tested and that is bad the guy at AutoZone said. But over the weekend I ran some off road light wires and obviously had to disconnect the battery terminal connectors to hook the wires up to it. (All the wires are ran correctly) and when I finished up the truck would not start. Just one click and nothing. Not multiple cicks. Then it just randomly started. Started for a couple of days and then same thing happen again one click would not start. I messed with the starter relay on the firewall (one of the nuts will not get tight it's stripped out but is making good contact)
Then I wiggled the negative battery terminal connector around and the truck started. So I figured it was a bad negative terminal connector got a new one and same thing one click then nothing. Cleaned the wires up with battery cleaner and tried it again and now nothing is happening no power to anything like I have a dead battery but battery the battery is good. (Charged it)
WHAT IS THE PROBLEM?!
Sent from my SM-G935V using Tapatalk
