Unlock Door Code/ Unlock Remote
MN
03 is under the passenger side too. Thanks everyone. Had truck 2 months and was not going to pay dealer to "find" code out for me for a fee! Would have went wo code. Matter of principal.
T
Titus
Exeter RI
On my '00 it's a white box with black numerals. It is located next to the left kick panel as high up under the dash as it can be. It's a 5 digit number, can be read without removing anything. Numbers are appx 3/4 inches high...... Jim
Found it thank you!
lakmflx
P.C.B
On my 99 it is under the drivers side, black plastic box with a white sticker in black lettering.
Paul
Virginia Beach, Va
I know that this thread is a bit old, however this topic seamed the most relevant for my post.
As a note of reference, the location for the 08's is on the Smart Junction Box(SJB), located behind the passenger side kick panel. The SJB is secured with 2 8mm screws and the code is affixed to back side of the box on a small white sticker at the top right corner.
Logic would dictate that this "should" also apply to the 07's as well, seeing as they are on the T1 Platform.
Seawolfbronco
Louisiana
Awesome, I just bought an 08 and didn't get the code. I thought I'd be able to pull it with my AutoEnginuity scanner, but couldn't read anything but powertrain. AI now has an upgraded tool that reads all the modules, but they want another $200 to upgrade. :mad:
Paul, you've saved me a trip to the dealer! Thanks
joezek
psl, FL
Thanks for the info guys. I found mine, pass side kick panel, black box mounted on side wall. It was in the forward most point of that area but I did not have to remove anything. All I needed was a flashlight.
2003 model
99 xlt
ohio
keyless entry buttons not working
im new to this forum and not sure exactly how to post or respond...
i have a 99 expy. xlt i found the code way up under driver side dash exactly as you described it. the problem is that only some of my buttons light up. the 1/2, 3/4, and 5/6 buttons do nothing at all as the 7/8 and 9/0 buttons work fine. my code requires me to use some buttons that do not work. is there a chance that the buttons themselves are bad and need replaced/cleaned, or do you think thats its a module issue. thanks in advance
TIKT B8
Austin, Texas
Beginning in '07, the code is not printed on the vehicle, you must go to the dealer to get it.
That is what I was told and never found anything on my 07. But...on another forum someone found it. It is located on the (SJB) smart junction box, Passanger side fuse box, remove the plastic panals and look on the rear of the fuse box you will see a sticker with the code. No tools Required!
7hmK
7hmQ
