pohoda
$140 shipped to lower 48
Hypertech Power Programmer III 04-05 Ford Truck & SUV Part # 41043 For sale is a Hypertech Power Programmer III for a 2004 or 2005 Ford F-150 or Expedition with the 5.4 liter Gasoline V8 engine. Hypertech's Power Programmers are some of the best bang you can get for your buck. You'll increase your horsepower and improve performance! This programmer is like new and is ready to use! The part number is 41043. Programmer is VIN unlocked and ready to be installed on another vehicle This Programmer will work on the following vehicles: 2005 FORD EXPEDITION V8 5.4L GAS FI 2005 FORD F-150 FX4 V8 5.4L GAS FI 2005 FORD F-150 KING RANCH V8 5.4L GAS FI 2005 FORD F-150 LARIAT V8 5.4L GAS FI 2005 FORD F-150 XLT V8 5.4L GAS FI 2005 FORD F-150 XL V8 5.4L GAS FI 2004 FORD F-150 PICKUP V8 5.4L GAS FI Hypertech Power Tuning Features Tunes the engine for maximum power and performance, plus potential gas mileage improvements Three-Stage Power Tuning Special Three-Stage Tuning for Select Vehicles Dual Fuel Tuning Lets you choose optimized tuning for 87 octane or 93 octane fuel Engine Rev Limiter Extends the engine's RPM range for a wider power band Cooling Fan On/Off Temperatures Permits use of low-temperature thermostat for cooler, denser intake charge and lower engine operating temperature Transmission Shift Points Optimizes shift points by speed and RPM for maximum acceleration Transmission Shift Firmness Firmer full-throttle gear changes for faster acceleration Top-Speed Limiter Allows the vehicle's top speed to be matched to the speed rating of factory-approved high-performance tires Speedometer/Odometer Correction Automatically corrects speedometer and odometer readings for non-stock tire sizes and/or non-stock rear-end gear ratios (accurate odometer readings are required by law) Read and Clear DTC's I have the Original Box, Programmer, Connection Cable, And Installation Manual.
